Freelander Talk about the Land Rover Freelander within.
Knock when i shift
Old Oct 3, 2007 | 02:25 PM
mkIIdude's Avatar
Default Knock when i shift
Well when i am driving and i take off from a light and im open throttle on the gas and shift into second there is sometimes like a hard knock, but it doesnt seem to do anything just curious if somebody else has this problem, the suv is 02 freelander S
thanks
Old Nov 30, 2007 | 05:21 PM
redsfan54321's Avatar
6th Gear
Default RE: Knock when i shift
Hi my 01 freelander had the same sort of noise when I changed gear. Sort of like a knocking noise coming from under the car somewhere. I took it for it's MOT and mentioned it to the mechanic and he fixed it saying it was just a loose bush. Did it for free! Result! So yours could be something equally as simple to fix. Hope so dude.
Old Feb 19, 2008 | 01:33 PM
Blippie's Avatar
Most likely the VCU mounts or the front mount on the rear diff. Get under and have a good investigation by grasping the propshaft and twisting and pulling it. Both are relatively easyto sort.
Cheers
Blippie
coors
Jan 11, 2013 09:28 PM
gtuplin
Jul 15, 2012 12:18 PM
salve7
Jan 7, 2010 02:34 PM
targotsi
Feb 18, 2009 05:58 PM
stick
Jan 27, 2008 01:29 PM
