Freelander Talk about the Land Rover Freelander within.
Radiator
Old Feb 3, 2018 | 12:41 PM
broncoupe's Avatar
7th Gear
Default Radiator
Hi all have an 05 freelaner mk1 petrol with air con
Does someone have instructions to replace radiator mine is blocked
thank you
Old Feb 3, 2018 | 10:26 PM
XCELLER8's Avatar
download a copy of the RAVE service manual for your vehicle......pretty well detailed there
Old Feb 4, 2018 | 04:01 AM
broncoupe's Avatar
7th Gear
Default Rave
where do i download it or buy a copy from
Old Feb 4, 2018 | 10:18 PM
XCELLER8's Avatar
a lot of the members have the link in their signature...."WaltNYC" has it in his sig...
Old Feb 5, 2018 | 01:37 AM
broncoupe's Avatar
7th Gear
Default Thank you for info
Mine defo radiator
after head gasket used heavy duty flush 3 times
I think it wakened hoses because on test drive had pin ***** spray on return when System pressured up
checked temps with a laser heater gauge and although engine temp on the gauge read Normal
actual temps on hoses where different and the rad also had hit and cold spots
i changed all the hoses and went also for rad that is not a nice job all self tappers on front bumper where corroded
removed them with an easy out fantastic highly recommend them
managed to remove radiator by leaving fans in place and sliding rad up on bumper side through the small gap as didn’t want to remove A/c condenser
all back together temp gauge still shows normal
though now even temps every where I check
still find it odd how thermostat stays shut most of time but our outside temp presently around 5 degrees
it must be design of system 😁
Old Feb 21, 2018 | 03:05 PM
hichamaziz's Avatar
hi if don't know you must give it to an expert
ferrelltodd
Dec 8, 2005 02:46 PM
SARAH1
Freelander
Oct 30, 2005 12:05 AM
Evian
Sep 10, 2005 01:39 AM
Rcraig
Aug 4, 2005 10:11 PM
nickvillaume
Jul 19, 2005 01:52 PM
