Freelander Talk about the Land Rover Freelander within.
Rear door not opening
Old Dec 28, 2018 | 11:43 AM
Alan Broadway's Avatar
Default Rear door not opening
Hello, I own an 04 two door Freelander the rear tailgate door has decided not to open the window will open but not the door sounded like something jammed when the window opened ,the window operates as per normal still can the door panel be removed to see what is jammed with the door closed . ??
Old Dec 28, 2018 | 04:40 PM
stillruns's Avatar
Dig in and give it a try! Post some pics while you're at it. Not many Freelander questions on the forum here.
Old Feb 4, 2019 | 12:16 PM
Imag5566's Avatar
I had this problem. It turned out to be a loose connection in the handle. This was after I had changed the mechanism and solenoid, which did not cure the vault. To get the rear door card off with the door closed is a mission. First you must undo four screws that hold the card on the bottom. All four are barstewards to get to and a flexible bit holder would be the best tool or a right angle screw wotsit (like Allen key). The first time I opened the door I physically managed to wiggle a right angled bit of coat hanger to actuate the solenoid mechanisms, but the best way to open the door is to indentify to wired to the solenoid and run 12v to it and the door will pop open.
now you can check the connections to the handle and the door mechanism. make sure sure all works before putting the door card back on and shutting door again. I put a button to the door opener, so that I can open the door from the inside should this happen again.
Go to you tube for video to give better idea.
can take some pictures if needed further.
Old Feb 28, 2019 | 12:22 PM
Roburite's Avatar
Default Youtube
Can you give a link to the Youtube video please.
Old Mar 1, 2019 | 12:07 AM
Imag5566's Avatar
Old Mar 1, 2019 | 04:18 AM
Robert Allinson's Avatar
ohh the same problem I have faced that was a very bad day of mine i was somewhere i tried everything, after all, I call my friend who was running a company of Roadside Assistance Services. but the day was very bad.
cornercase
Apr 26, 2022 08:17 AM
huggi
Apr 23, 2018 09:45 AM
RossN99
Dec 7, 2017 08:43 PM
petstarfish
Mar 25, 2013 09:44 PM
ryan884
Mar 16, 2013 08:55 AM
