Freelander Talk about the Land Rover Freelander within.
Rear Door Problem
Old Mar 19, 2006 | 01:11 PM
redmel's Avatar
3rd Gear
Default Rear Door Problem
Having trouble closing the rear door on a 5 Door Station Wagon, sometimes coses, sometimes bounces straight back at me, other times it part closes and you have to give it a nudge.
Is there any easy solution to look for, or am i looking at replacing locks, catches and brackets etc ????
Thanks in advance if you can help
sorry its a 2000 GS model
Old Mar 23, 2006 | 02:15 AM
LRGuru's Avatar
8th Gear
Default RE: Rear Door Problem
Sounds like the latch on the door might need to be replaced. Aslo make sure the bracket that the latch closes on is lined up with the door latch.
Old Apr 23, 2006 | 08:10 AM
rinmud's Avatar
Make sure the window is dropping once you release the latch sometimes the window regulator stall and it makes it a bitch to close easily tested by the switch in the center console
jigray3
Jul 30, 2019 07:52 PM
yellow600r
May 12, 2010 04:03 PM
Shadley
Aug 6, 2009 08:11 AM
Benhamtroll
Jun 28, 2006 04:08 AM
