Freelander Talk about the Land Rover Freelander within.
Rear window not lowering. & coolant leak
Old Dec 12, 2008 | 12:05 PM
oneohsix's Avatar
8th Gear
Default Rear window not lowering. & coolant leak
02 Freelander(my daughters car and she loves it) has the typical coolant leak issue. I have to add about a cup every week. No sign of the coolant in the oil or anywhere else. However, I do have oil droplets in the reservoir. Headgasket and /or thermostat?
On the rear window. When you press the latch the window lowers but not quite enough to clear the plastic trim. I can open the door but it scrapes the trim. After opening I can push the window down about a quarter of inch and thusly shut the door. I am concerned that one day it will not go down enough and prevent the door from opening. Is there any adjustment or has something come loose worn out in the track? I noticed this after the battery was replaced. I went through the set window preocedure but is there something I am missing?
Old Dec 15, 2008 | 09:33 AM
freelanderjames's Avatar
8th Gear
Default RE: Rear window not lowering. & coolant leak
On the rear window issue I had the same thing happen to me. I had to take the back panel off and saw that the scissor track had come just loose. also you can roll the window all the way down , then disconnect battery for 10 mins then reconnect. roll window all the way up and see if it reset itself. This had worked for me once. I am a BMW tech for pre2002 models and this is the poor mans way of doing it.
I dunno if it helps but thought I would throw it out there.
Old Dec 20, 2008 | 06:09 AM
rinmud's Avatar
hes rite about the reset but more the likely your regulator too a st. coolant leak look at the bottle and see if you see any orange juice, then pull the air filter housing off and look into the valley of the intake for same (thermostat housing) scott
twoxred
Oct 4, 2021 07:07 AM
ZMonet
Jun 24, 2016 04:00 PM
turf63
May 4, 2012 09:15 AM
longjon76
Apr 8, 2011 12:29 PM
tulsa
Jun 27, 2010 06:01 PM
