Rear Window Recalibration
if you disconnect the battery you should be able to go all the way and all the way down and it should calibrate. If it does not then something isn't working. You will need to take it to the dealer because we have to look at the status of the door and all of its components like the rear wiper, the switch status etc. And if everything is good and we can't calibrate it its possible the motor is bad.
twoxred
10-04-2021 07:07 AM
Jedelmann
02-18-2015 07:30 PM
