Resetting SRS indicator
Check seat belt pre-tensioners, there is a sensor in each. Then unplug, check, and replace fuses 23 and 18. After that it will be time for the dealer or a very advanced scanner, the SRS has a dedicated ECU that is on the OBDII port, but can't be read by a generic engine code reader.
