Freelander Talk about the Land Rover Freelander within.
Touch Screen Issue
Old 01-19-2020, 03:15 PM
Obrien.james's Avatar
Default Touch Screen Issue
Hi
I have a 2013 Freelander 2 HSE LUX. The touchscreen has developed an odd fault - it’s not responding to touch.
The screen shows all the correct info/nav and the hard buttons under the screen (Audio/Nav/Phone etc...) however the screen has stopped responding to touch.
it started with the calibration going off - when touching the screen it would think im touching higher than I was. Then stopped responding to touch all together.
Has anyone seen this sort of fault before / any suggestions as to how to fix it?
cheers
james
Old 02-12-2020, 05:11 AM
lolarew's Avatar
Originally Posted by Obrien.james
Hi
cheers
james
Hi James,
The very same has happened to my Freelander 2 XS SD4 2013 . I have the added problem that the Sat Nav does not work. I am in the South East, the Sat Nav thinks it's in Brussels, this has been going on for a year, which up until this point was fine as I didn't use it. Since the past month the screen stopped responding to telephone, then when I took the car in for its service the garage said that the touch screen had a problem and looks like it would need to be replaced. Having gone away to it over, now I have the added problem that the Sat Nav is constantly giving me commands trying to get home from Brussels, where the car seems to be stuck and I can't turn the directions off as the screen does not work. Awful. Anyhow, the long and short, I have the same problem but have no idea how to address it unless the screen is replaced, priced up at £1,350 for the screen.
I would be interested to see if you receive any replies from someone who has had the problem and had it solved without going to replacing the screen.
Cheers,
Lola
turboz32
02-26-2017 09:06 PM
DaveWinCO
03-22-2016 07:24 AM
Zooropa
06-28-2011 07:24 PM
ashmarie73
11-27-2010 12:46 PM
bigswilson
04-29-2008 06:02 AM
Quick Reply: Touch Screen Issue
