Freelander Talk about the Land Rover Freelander within.
Transmission Fluid
Old Mar 7, 2007 | 01:23 PM
Rock*Star's Avatar
Default Transmission Fluid
I just got a 04' Freelander and have no Idea where to put tha Transmission Fluid. Help Me Out!
[/align]
Old Mar 25, 2007 | 01:03 AM
sharpy's Avatar
4th Gear
Default RE: Transmission Fluid
looking down with hood opened right between battery and engine (trans area) you'll see a small black rubber plug pull that out and fill her up!!!
Old Mar 26, 2007 | 12:03 PM
Make sure if you add or replace ATF in a Freelander that you use only the one fluid that is reocmmended by Rover, any other ATF's can kill the tranny.
Mike
Old May 17, 2007 | 05:41 PM
blue marbles's Avatar
3rd Gear
Disco Mike,
Would you know what ATF is used in the 02' Freelander and recommended by LandRover? (specifications) or a link that would have this info.
Is there no other compatible ATF that can be used with the same specification, i.e. syntheticATF or Dextron III?!?
Blue M.
Old May 18, 2007 | 07:25 AM
You have to buy the ATF from Rover. I have spoken with a shop on this issue and they have seen 2 trannys that died from using the wrong fluid, what a bummer.
Mike
Athana
Jun 8, 2019 10:23 AM
Rolltop
May 5, 2014 09:17 AM
1998DiscoverySE
Jul 20, 2012 08:02 PM
LRScott
Mar 4, 2009 08:39 AM
ferrelltodd
Aug 9, 2005 10:11 PM
