Freelander Talk about the Land Rover Freelander within.
Trouble Code: P1605
Old Oct 9, 2008 | 06:52 PM
F@#$lander1's Avatar
Default Trouble Code: P1605
Check engine light has come back on with the usual suspects that will be dealt with tomorrow but 1605 is a new one. Anyone know what this is?
Old Oct 9, 2008 | 10:01 PM
tacomatech's Avatar
Default RE: Trouble Code: P1605
I believe that fault is for the transmission ecu. It is Internal EEPROM Fault. Clear it and see if it returns. If it doesn't then don't sweat it, if it does, then dig deeper.
Old Oct 10, 2008 | 11:17 PM
Code cleared, so far so good, replaced the evap purge valve today too to correct the 147* codes. So naturally I have a new problem, SRS light is on and OBD scanner comes up with nothing. Time to search the forums archives as I'm sure I've seen this posted before.
Old Oct 10, 2008 | 11:29 PM
tacomatech's Avatar
For the SRS light, you will need T4. I haven't seenthe SRS light on in many Freelanders, so my memory is a little foggy. Let me know what fault you come up with.
Old Oct 10, 2008 | 11:51 PM
Yikes, by T4 we're talking Testbook or similar here right? Don't have one of those laying around the house, I'll have to see about getting it into a shop sometime unless there's an affordable version available.
Old Oct 11, 2008 | 10:51 PM
tacomatech's Avatar
T4=Testbook, yeah, you will need to take it in for that one.
Gordon C Payne
Freelander
Jun 29, 2015 06:40 PM
Matt_Attack352
Jan 13, 2014 09:55 AM
saltyrover
Apr 25, 2013 06:44 PM
sayeedA
Nov 15, 2011 11:02 PM
dc10freighter
Aug 29, 2007 09:17 AM
