Freelander Talk about the Land Rover Freelander within.
vibration
Old Dec 25, 2008 | 08:51 PM
chvy383's Avatar
6th Gear
Default vibration
yes i have a 2002 freelander when going 65 mph i'am getting a vibration but when i let off of the gas it go's away? can anyone help me out. it has a 102,000 miles on it
Old Dec 26, 2008 | 12:48 AM
rinmud's Avatar
Default RE: vibration
Check the center support for the drive sft rear see if rubber is pealing out of it... scott
Old Dec 26, 2008 | 12:17 PM
chvy383's Avatar
6th Gear
I checked the center support no rubber can't really tell were the vibration is coming from thinking about taking off the rear prop shaft and drive it to see if that helps.
Old Dec 26, 2008 | 05:19 PM
rinmud's Avatar
at first i was thinking 04 Jaguar (same transfer case) and saying WHAT, yes the center is viscous it will still move, good shot and simple. watch out for the oxygen sensor wires in the clips or you'll be back scott
Old Jan 3, 2009 | 12:35 PM
chvy383's Avatar
6th Gear
Hey i found my vibration the front cv joint the grease had leaked out of the boot the boot was not bad so i sliped it off and repacked it with grease put the boot back on with a universal cv boot clamp on. And no more vibration Yes!!!!
Kiwi Mike
Mar 2, 2006 07:32 AM
kennims
Jan 22, 2005 08:22 AM
Greyfoxvt
Jan 9, 2005 09:04 AM
berg7171
Dec 27, 2004 06:35 PM
Benhamtroll
Dec 13, 2004 04:35 PM
