03 HSE Radio Non Existent
Old Aug 22, 2010 | 08:39 PM
grussell's Avatar
Default 03 HSE Radio Non Existent
Radio does not turn on or work. Nav works, on board computer works, no other problems. Radio just stopped working.
Old Aug 24, 2010 | 06:31 AM
Rovin4life's Avatar
check out the back for corrosion in the nav unit and the radio and the amp. if the stuff has power and ground then you need to swap out a known good amp and or radio unit.
Old Aug 27, 2010 | 06:35 PM
grussell's Avatar
Is the radio unit in the dash or in the left rear qtr compartment?
Old Aug 29, 2010 | 06:04 PM
grussell's Avatar
Well, took the Rover to a stereo shop and they said they diagnosed a bad radio unit. So, I went home and pulled the radio unit out and was going to order one from car-part.com. I noticed a small 10a fuse and pulled it out and held it up to a light and it looked good, but for kicks I tested it with my ohm meter, viola, bad fuse. I replaced the fuse and put her all back together and the radio works!
Old Aug 29, 2010 | 06:51 PM
lordmorpheus's Avatar
Awesome! This is a good example of why its always best to perform a thorough test (checking resistance on the fuse) rather than just using observation (the fuse looks good). How much money did you save by taking an extra 5 seconds to properly test the fuse?! Whatever the amount, I'm sure it's a good time/dollar ratio!
Old Aug 30, 2010 | 12:10 AM
LRScott's Avatar
Good job! Always start with the most simple and CHEAPEST thing before moving on to the big ticket items. Well done. I am guilty of starting with the most expensive thing (worst case scenario), it never pays off.
dogstarsix75
Apr 24, 2020 01:33 PM
lvshust
Aug 21, 2018 02:29 PM
moocowman
Aug 31, 2011 04:07 AM
southfloridadiscoII
Jun 28, 2009 11:03 PM
