03 Range Rover hse sitting low in the rear....????
Old Oct 4, 2009 | 12:32 AM
yukonridin23's Avatar
Default 03 Range Rover hse sitting low in the rear....????
hey everyone. i bought a3 range rover hse a couple months back with a coil over conversion already done. well ever since i got it has sat really low in the back and squats when i get on the gas. any suggestions, do you think maybe tightening the coils would help, they are really soft in the back. how hard is it to convert it back to the airride, i would very much prefer it.....any help is greatly appreciated...
Old Oct 4, 2009 | 08:52 AM
NiveK1970's Avatar
you can't tighten coils, you probably have the coils for the front on the back, the coils are marked if you got them from strutmasters, 31's go on the back and the 30's go in the front, i just did my conversion and it's perfect
Old Oct 4, 2009 | 11:12 AM
handsome rob's Avatar
I have no idea of what the reason is, but if the coils were swapped then would it not make more sense that fronts would be stiffer since it holds the engine? Or is it a length issue as well instead?
Old Oct 4, 2009 | 11:36 AM
NiveK1970's Avatar
rear springs are actually always stiffer because they would be asked to carry cargo, trailer etc. thus they would need to be a bit stiffer than fronts, engine isn't as heavy as say a few adults in the back and 6 or 7 bags of dog food
Old Oct 4, 2009 | 03:00 PM
LRScott's Avatar
Air ride is not necessarily hard to do, its just expensive. If I had the money, I would be switching mine back to EAS.
Old Oct 4, 2009 | 05:26 PM
yea, i think its all their besides the air-struts. ill try to look for a label on the coils, if there isnt any, is there another way to tell. the front is deffin itely alot stiffer than the rear i think. how hard is it to switch them around? id guess about an hour or two on some jack stands?
Old Oct 4, 2009 | 05:32 PM
NiveK1970's Avatar
you will need a spring compressor for the front, looking at 3 to 4 hour job, and i can't tell the springs apart without that label, they where identical in length
Old Oct 4, 2009 | 10:48 PM
I was thinking back to my Jeep days, the fronts were wound tighter and stiffer than the rear and were definatley longer in length, the rears had a wider spacing and was shorter.
nboulle
Jan 6, 2014 09:00 PM
nboulle
Jan 6, 2014 08:58 PM
Murph_Dog
Feb 15, 2010 10:57 PM
dalfier
Aug 30, 2007 02:20 PM
