06 RRS Battery Replacement
Old Oct 11, 2008 | 06:57 PM
hockeydoof's Avatar
Default 06 RRS Battery Replacement
Hello, battery is dead in 06 range rover sport. must i replace it with a factory replacement, or will the optima series work? also open to other cost-effective replacements.
additionally, just before the battery died, i received a transmission fault message and was unable to shift out of 'park'. is that caused by the low voltage, or is it something the dealer should look at?
thanks, russ
Old Oct 11, 2008 | 11:02 PM
tacomatech's Avatar
Default RE: 06 RRS Battery Replacement
The fault messages are caused by the low voltage. I have seen Optimas installed, they will work.
Old Nov 10, 2008 | 05:18 AM
nuyorican420's Avatar
7th Gear
Optimas are trash, Try a Sear's brand Odyssey...http://www.sears.com/shc/s/p_10153_1...rine+Batteries
Old Nov 10, 2008 | 08:59 AM
So, if you go do your home work, I believe you will find that the Sears battery is a lessor quailty of the Odessye.
What is it that you have against the Yellow Top, did you have one that failed or are you one of those that just likes to spread the hear say information around?
Old Nov 11, 2008 | 11:22 PM
tacomatech's Avatar
I had a red-top Optima that sat in my Mustang discharging for 2.5 years, completely died, trickle charged it for 2 hours and it is back to new output and haven't had any problems with it since.
nateandnikki
Jul 2, 2013 06:38 AM
xoo00oox
Jan 11, 2013 06:23 AM
Chrisinhouston
Jan 12, 2008 07:55 AM
audiurq
Feb 15, 2007 09:44 PM
arrkerr
Dec 14, 2005 10:06 AM
