100,000km Service Requirements?
I have a 1999 P38 Range Rover HSE and it came without a manual. Russian dealerships seem to have a lot of trouble with the concept of carrying out a service as per the log book, I can't seem to make them understand it!
If someone could post the 100,000k service highlights at least I could get them translated into Russian and say 'check this' and 'change that'.
Please help!
Please help!
At 105K the following is recommended:
1. Change engine oil filter. We recommend Mobil 1 Extended Performance.
2. Check transmission fluid. Check steering linkage joints. Joints should all be good and tight.
3. Check brakes
4. Check exhaust and under car components for damage
5. Replace wipers if bad
6. Check lights
7. Check a/c and heat
8. Check all accessories
9. Check washer jets, clean and adjust if needed
10. Rotate tires
11. Road test and note other problems. Check front and rear axle oils.
12. Check and top all other fluids
13. Check swivel housings
14. Check transfer case oil
15. Oil all door and body hinges
16. Grease drive shaft joints
17. Replace spark plugs
18. Clean air filter
19. Check steering linkage joints. Joints should all be good and tight.
20. Check brakes
21. Check exhaust and under car components for damage
22. Replace wipers if bad
23. Check lights
24. Check a/c and heat
25. Check all accessories
26. Check washer jets, clean and adjust if needed
27. Rotate tires
28. Road test and note other problems
3. Check brakes
6. Check lights
10. Rotate tires
20. Check brakes
23. Check lights
27. Rotate tires
kcferna
07-07-2009 08:33 AM
nfit
11-29-2008 03:43 PM
