100,000km Service Requirements?
Old Jan 20, 2010 | 10:53 AM
Russian_Rover's Avatar
Default 100,000km Service Requirements?
I have a 1999 P38 Range Rover HSE and it came without a manual. Russian dealerships seem to have a lot of trouble with the concept of carrying out a service as per the log book, I can't seem to make them understand it!
If someone could post the 100,000k service highlights at least I could get them translated into Russian and say 'check this' and 'change that'.
Please help!
Old Jan 20, 2010 | 05:06 PM
ldivine's Avatar
At 105K the following is recommended:
1. Change engine oil filter. We recommend Mobil 1 Extended Performance.
2. Check transmission fluid. Check steering linkage joints. Joints should all be good and tight.
3. Check brakes
4. Check exhaust and under car components for damage
5. Replace wipers if bad
6. Check lights
7. Check a/c and heat
8. Check all accessories
9. Check washer jets, clean and adjust if needed
10. Rotate tires
11. Road test and note other problems. Check front and rear axle oils.
12. Check and top all other fluids
13. Check swivel housings
14. Check transfer case oil
15. Oil all door and body hinges
16. Grease drive shaft joints
17. Replace spark plugs
18. Clean air filter
19. Check steering linkage joints. Joints should all be good and tight.
20. Check brakes
21. Check exhaust and under car components for damage
22. Replace wipers if bad
23. Check lights
24. Check a/c and heat
25. Check all accessories
26. Check washer jets, clean and adjust if needed
27. Rotate tires
28. Road test and note other problems
Old Jan 21, 2010 | 08:13 AM
That's brilliant thank you!
Could you advise of anything significant at 95,000km? Like timing belt or others? Then I can ask them to chek if they have been done.
Thanks again!
Old Jan 21, 2010 | 10:53 AM
LRScott's Avatar
Rovers use timing chains, no need to replace it .
wright_LC
Feb 16, 2014 06:55 PM
kcferna
Jul 7, 2009 08:33 AM
mr_boondoggle
Freelander
Jan 2, 2009 09:32 AM
nfit
Nov 29, 2008 03:43 PM
ROW
Feb 20, 2006 12:29 PM
