1989 RR hydrocarbons in 2400ppm range
Old Sep 19, 2011 | 12:22 AM
Frank4's Avatar
Default 1989 RR hydrocarbons in 2400ppm range
I knew this truck was not going to pass emissions inspection but I ran it through for a baseline. The acceptable range is 220 ppm and this beast is spewing 2400 ppm. The truck has a 4.6 short block from a 2003, rough idle but doesn't die. I changed the plugs and it now has a little smoother idle but not much. My plan is to change the oil/filter change air filter, O2's and retard the timing to smooth the idle. I want to avoid getting new cats just because of cost. I can title it so I don't have to go through inspection but I would like to know if anyone has had any luck lowering hydrocarbons from 10x the acceptable limit.
Thanks
Old Sep 21, 2011 | 08:09 PM
Rovin4life's Avatar
check compression to make sure the valves are hanging up and the rotor is good. Seen aftermarket rotors cause all sorts of problems.
Old Sep 26, 2011 | 12:48 AM
Frank4's Avatar
Thanks, I will give it a look.
jna97
Nov 12, 2012 06:07 PM
Blackheart
Jan 27, 2009 10:06 PM
Classic89
Oct 6, 2008 07:51 PM
Chain
Member Group And Special Buys
Sep 29, 2008 10:39 PM
amphibxp
Jul 10, 2007 06:43 PM
