1992 Classic 3.9L V8 Runs Poorly When Hot
Old Oct 20, 2016 | 08:09 AM
Dbull's Avatar
Default 1992 Classic 3.9L V8 Runs Poorly When Hot
Need help……1992 Classic 3.9L V8 starts when cold, runs smooth for approx. 15 minutes until hot then starts to run ruff until it finally stalls. Will barely restart. No power at all. When placed into gear, really barely runs. Exhaust really smells. No Check Engine Lite, no codes. New distributor, fuel pump, fuel filter, replace air flow sensor, no change… Any ideas?
Old Aug 7, 2017 | 12:59 PM
Brock88's Avatar
Check fuel pressure regulator and the vacuum line connected to it. Cracked vacuum line or broken fuel pressure regulator diaphragm causes a rich condition at idle.
With the engine off, apply vacuum to the FPR and see if it holds.
Also look at oxygen sensors.
Old Aug 8, 2017 | 06:03 AM
Check the catalytic converters as well see if they are glowing cherry red.
ajnolin
Dec 2, 2013 11:26 PM
seamonkey1
Sep 26, 2011 08:43 AM
edwardthe3rd
May 27, 2011 05:14 PM
seamonkey1
Mar 29, 2011 08:50 PM
masher
Apr 30, 2008 02:45 PM
