1995 Range Rover 4.0
Old Oct 9, 2007 | 01:38 PM
maxRS's Avatar
Default 1995 Range Rover 4.0
I am looking at purchasing a 1995 Range Rover 4.0. I did all my research and I know about all the occuring problems with these SUV but am not worried about that too much as this truck has been taken care of.
Anyways I had the truck for a 24 hours test drive,which was awesome everything was running really smooth.. But the one thing I have noticed is that the compressor was kinda noisy and was turning on quite often is that normal???
Also right when I start the ABS would show on the dash for abput 2 minutes and than dissapear.
The before me shorted out the computer by putting the wrong alternator but had it replaced and everything seems to be working.
The rearmirrror is leaking, and the passenger window makes noise when it rolls all the wayup.
Any help would be greatly appericiated.. Things I should loook for?
The truck has 197 000 KM.
Old Oct 27, 2007 | 07:58 AM
olivia's Avatar
Default RE: 1995 Range Rover 4.0
Hi - I bought my 95 P38 about a yr ago. This is the fouth Range rover i have owned. I have a had a ton of things to do to it but it is worth every hour and penny!!!!!
The rear mirror for instance I had the same problem and found one on e-bay for $50 There are quite a few series 2's being pulled apart for parts I have noticed. The price of new parts are pretty high.
You will need a code reader (leave it in the glove compartment) and a CD of the workshop manual.
I got a cheap 2nd hand laptop for my garage just to run the disc - (its about a 1000 pages - PDF)
The forums are a great support system, I have contacted owners of Range Rovers around the Globe, some of them are 6-800 miles from their closest dealers. They have no option but get on their satelite connection and use the network!!
If you can read and use the computer, have some good mechanical instincts, It will all make sense.
A lot of the work you will be able to do yourself, mine has only driven past the dealer like introducing the Gin to the Vermouth .
Don't be intimidated, you will be working on it weekly. But It is the ultimate!!!
All for now
Good Luck
Old Oct 27, 2007 | 10:21 AM
maxRS's Avatar
Thanks for the info!! I did get the Range last weekend and I love it. It's like nothing else.
Curious if you guys can help me, couple days ago one of my passenger pulled on the interior door handle when the doors were locked now the door wont open from the inside but it will open from the outside.. Any help would greatly be appreciated!!
Old Nov 2, 2007 | 02:10 PM
burnhad's Avatar
You are going to have to remove the inside door panel (not difficult) and reattach the rod linking the inside door handle with the door latch.
harrellee
Jun 9, 2011 05:29 AM
das
Dec 25, 2006 09:20 AM
kspider
Feb 6, 2006 02:57 AM
saka24
Audio/Visual Electronics
Aug 11, 2005 07:19 PM
deb
Nov 5, 2004 02:23 PM
