1996 4.0 p38
Old Sep 24, 2012 | 09:01 PM
CMOVEMENT's Avatar
Default 1996 4.0 p38
My 96 stalled on the highway. I thought I ran out of gas. I added more Gas and it did not start. I waited a few days still no start. Please help.
Old Sep 25, 2012 | 06:15 AM
Start with basics.
Unplug a plug wire, connect to a spare plug, lay on manifold, crank - any spark? If no spark suspect crank shaft position sensor if you have a model that does not have a distributor at front of engine (thing with 8 plug wires coming out of it).
If you have a distributor and no spark - suspect ignition amplifier.
If you have sparks check for fuel pump running (should run for a second or two when key switched on). Fuel pressure test point on injector rail (right side of engine) - looks like a tire valve. 32-34 PSI would be expected. No or low pressure consider fuel pump (or electrical to same) and fuel filter. Also press reset button on top of inertia switch on firewall. It turns off fuel pump in a crash.
faversham
Oct 20, 2009 04:34 PM
Gary N
Jun 13, 2009 02:19 PM
les mitchell
May 14, 2008 12:22 PM
WF31QA
Aug 14, 2005 01:17 AM
WF31QA
Aug 1, 2005 05:21 PM
