1999 Range Rover 4.0SE
Old Oct 2, 2008 | 07:38 PM
pjpri's Avatar
8th Gear
Default 1999 Range Rover 4.0SE
Just bought this vehicle....can anyone tell me if there is a way to fully turn off the heating/cooling system. I've tried to lower the fan all the way and I can only get it to 1 bar. I've tried fan at lowest and hit A/C off but system (display) stayed on. Does it just stay light all the time or do I have an electrical issue?
Please advise.
Thanks
Peter
Old Oct 3, 2008 | 10:40 AM
Rotorhead1959's Avatar
Default RE: 1999 Range Rover 4.0SE
If you have the owners manual (I am assuming you don't) there is a full explanation on how the system works. Here is what I can tell you and it is only a partial answer. The light on A/C button when lit means the a/c is off. Turn off all defrost modes and see if your fan **** will allow you to turn it off. Also, be sure you have the auto climate control turned off. If that is left on, the system will stay active and try to maintain the temp settings you have chosen. I know there are some sites out there that will give you full (out of the manual) instructions on the HVAC system. Hope this helps...a little.
Old Oct 3, 2008 | 12:53 PM
pjpri's Avatar
8th Gear
Correct...I do not have the owners manual. I have tried your scenario...A/C off ....all Auto features and defrosters off and turned the fan control counter clockwise so all the bars no longer show and the system still stays on. I'm assuming it's still on because I the display is still lite with temp numbers showing. I'm guessing I must have an electrical issue or a bad unit. FYI...the unit does work properly.....just can't shut it off. That's why I thought that maybe they are always lite.......
Old Oct 3, 2008 | 01:02 PM
sorry I couldn't help. If you do find the issue, keep us all informed. I love this forum. Lots to learn and share.
Old Oct 4, 2008 | 03:29 AM
tacomatech's Avatar
Unless I am wrong, that is normal operation. All of the 4.0/4.6 I've worked on do the same thing. Fan speed all the way down and display/control unit still illuminated, do you hear the blower motor running?
Old Oct 4, 2008 | 08:37 AM
Federal regulations require, even with the system off, that a given amount of air be moved through the passenger compartment in a given time. This is true on all vehicles and more noticable on some like your truck.
Old Oct 4, 2008 | 11:17 AM
pjpri's Avatar
8th Gear
That's good news......one less thing I have to be concerned with.....Thanks to everyone!
First time I used this forum and I'm sure I'll be using it regularly.
Great Forum
Thanks
Peter
1999SE40
Nov 16, 2014 11:25 AM
geeknc
Apr 24, 2013 01:57 PM
The Threat
Oct 28, 2010 09:14 AM
pjpri
Nov 10, 2008 05:07 AM
golfpro
Oct 18, 2004 04:50 PM
