1999 Range Rover HSE suspension help!!!
Old Nov 16, 2012 | 07:00 PM
Cottrell's Avatar
Default 1999 Range Rover HSE suspension help!!!
Ok, so for all the people that have been helping me along the way thank you. Now for the bad, I just got done rebuilding the compressor and the valve block on my Rangie but she wont come off the bump stops. No leaks on the valve block (checked with soapy water) no leaks on the front air bags (also soapy) could not access the rear air springs the car is too low. It seems like the front of the car starts to come up then sags back down. I'm thinking bad rear air bags? Is it lifting then leveling with the rear? Also I could not find the reservoir tank for the compressor so I haven't changed those O'rings yet. Any insight would be appreciated.
Old Nov 17, 2012 | 10:45 PM
Fivespddisco's Avatar
What are you using to reset the computer from the EAS fault?
Old Nov 18, 2012 | 05:30 PM
Cottrell's Avatar
I actually don't have any faults right now which is weird. I'm thinking a faulty air bag?
Old Nov 19, 2012 | 09:19 PM
Have you tried to manually fill the bag by disconnecting each airline and filling them individually?
Normally the computer will shut down the air system if it sees a fault.
Old Nov 20, 2012 | 02:18 PM
Cottrell's Avatar
The compressor still runs is that normal? I don't have a mars system so i cant manually air them up, I dont know where to find them either.
Old Nov 20, 2012 | 06:04 PM
Cottrell's Avatar
I give up going to the dark side of coil conversion.
Old Nov 20, 2012 | 07:46 PM
In the end it's for the best. Give me a call tomorrow and I'll do what I can to help you with a kit
omaromarvasquez
Feb 19, 2009 06:37 PM
krazyoljim
Sep 7, 2008 10:04 PM
scott222
May 3, 2008 11:21 PM
MusicMaster989
Nov 9, 2007 07:59 PM
Jim99
Oct 27, 2006 07:14 PM
