2000 RR Water in Spare Tire Area
Old May 26, 2006 | 04:01 PM
dbs600's Avatar
Default 2000 RR Water in Spare Tire Area
Hello:
I am the owner of a 2000 Range Rover and whenever it rains water accumulates in the spare tire area. After this happens, the water stays there for long periods at a time. Has anyone experienced the same? Is there any way to drain the water? The dealer wants 1 hour of labor just to figure out what is wrong ($115). Is there a common known fix for this?
Thank you so much,
JD
Old May 26, 2006 | 09:54 PM
Default RE: 2000 RR Water in Spare Tire Area
The floor drain in your spare tire area is plugged, pull the spare out and clean and open it up.
Now what you are going to need to find is the location of the leaks, most likely plugged drain tubes on your sun roof.
Mike
Old May 27, 2006 | 04:03 PM
dbs600's Avatar
Thank you for your reply. I'm going to attempt to remove the spare tire floor board so that the water will be able to drain. From there I'll try to pin down where the leak is actually coming from. Thanks for your input and enjoy your weekend!
Old May 31, 2006 | 07:55 PM
rinmud's Avatar
Its better to fix the leak look at the door seal on the tail door then make sure the taillamps seal arent leaking that is the usual problem water should not be getting in there
Old May 31, 2006 | 08:05 PM
rinmud's Avatar
Old Jun 1, 2006 | 01:58 AM
Bait's Avatar
LOL! no such thing as a floor drain.
ORIGINAL: Disco Mike
Mike
Old Jun 18, 2006 | 05:12 PM
dbs600's Avatar
i have not been able to find this spare tire well drain plug either. maybe it was only present on earlier models? before lr supposidly found a fix for this problem?
what i did do though was removed the spare tire and dry vac'ed the area. no water yet - but it hasnt rainned much since then.
ill keep you posted if i find a fix.
JD
Old Jun 21, 2006 | 11:09 PM
moneypit37's Avatar
My 94 RRC LWB has the mysterious rubber plug.
It's about the size of a 50 cent piece and is dead center in the spare tire floor pan.
I'm sure it is there for a reason on some models.
I agree with the liftgate idea.
With all the rust and corrosion happening there; if it is the original window and seals it probably does leak.
Is there any water stains on the headliner?
If not you know it is coming in at a lower point.
rovergirl74
Nov 2, 2013 04:12 PM
skipbrakes
Nov 5, 2007 07:36 PM
socalrover
Oct 28, 2005 05:17 PM
AzCamel
Aug 5, 2005 06:45 AM
GadgetRick
Jun 19, 2005 10:57 AM
