2003 Amp needed! Please help XQK000030
Old May 26, 2012 | 07:58 PM
ichione's Avatar
3rd Gear
is there anybody who need an original soundsystem for that line of cars ?
Old Jun 4, 2012 | 05:21 PM
gunnarL322's Avatar
Typically water leak in by the quarter rear window and with time cause corrosion in the DSP cabling. Or that corrosion can occur anyway out of electric processes. What typically happens is that the power pin (+12V) in the main havy gauge connector will corrode until it loses contact or breaks when you try to pull the connector. I solved this by opening up the DSP and soldered a heavy wire onto the +12V PCB wire and routed a separate lead out that I spliced into the 12V wire. And then the sound was back. These DSP amps are hard to come by and expensive. But I guess sometimes the fix is easy at least if you are a DIY with some electronics proficiency and soldering skills.
Old Mar 27, 2013 | 09:36 AM
beccit's Avatar
Is anyone selling a xqk000030 amp?
Bought my car in Novmeber with no amp fitted but been to land rover and they gave me the part number. Looking at 750 + VAT from land rover.
Old Jan 16, 2017 | 06:07 AM
dave in spain's Avatar
3rd Gear
Dynavin N6 L322 Range Rover with DSP Audio replacement Media unit
ivossss
Mar 12, 2011 01:52 PM
wolfgang528
Defender
Dec 28, 2010 04:25 PM
sean2k
Nov 4, 2010 03:52 PM
