2003 RR Transmission gear changing issues?
Hi I have a 2003 Rangie, which has recently just started not allowing me to get to 5th gear or at times 4th. It revs up to a high level in 3rd and will shift to 4th at about 4000 rpm, but then continues in 4th at about 2600 rpm , not the usual 2100 ( at 100 KMPH)
Even if I shift to sport it will not shift.
Has only occured twice , both times after a strong acceleration to pass another vehicle.
When I stop the car ( turning it off) for a few minutes it resolves and I can continue as if nothing has happened.
Any ideas?
I had the trans serviced as I thought it may be a filter/oil issue, but this has not solved the problem.
If I drive sedately then all is good, but at times I need extra acceleration to pass.
Thanks for your help
Greg
Any ideas?
Greg
Renee Nelson Barlow
04-01-2014 01:10 PM
