Sponsored by: CARiD
2003 RR Transmission gear changing issues?
Old Jan 17, 2011 | 04:02 PM
Greg's Avatar
Default 2003 RR Transmission gear changing issues?
Hi I have a 2003 Rangie, which has recently just started not allowing me to get to 5th gear or at times 4th. It revs up to a high level in 3rd and will shift to 4th at about 4000 rpm, but then continues in 4th at about 2600 rpm , not the usual 2100 ( at 100 KMPH)
Even if I shift to sport it will not shift.
Has only occured twice , both times after a strong acceleration to pass another vehicle.
When I stop the car ( turning it off) for a few minutes it resolves and I can continue as if nothing has happened.
Any ideas?
I had the trans serviced as I thought it may be a filter/oil issue, but this has not solved the problem.
If I drive sedately then all is good, but at times I need extra acceleration to pass.
Thanks for your help
Greg
Old Jan 18, 2011 | 07:47 AM
Prometheus's Avatar
This happened to me once a year or so ago. Like your issue, it resolved itself, but I still used my code reader to reset all codes (note, no codes read at the time). I haven't had the problem since. I don't know if it has been luck or the fact that I reset the codes, but may be something to try if you haven't yet.
Old Jan 20, 2011 | 07:03 AM
If it continues, get it into a tranny shop, not the dealer and have them read for fault codes.
Old Jan 20, 2011 | 09:56 AM
NhudeST's Avatar
I had the similiar issue when shifting over to manual mode. It turned out to be that it was my radiator that ended up ****-ing the fan. It was causing my trany to overheat, due to the coolant not being able to circulate and keep my main RR's components cool. I would check that first, then possibly the hoses while your at it. If all fails, have your trany inspected by a tech who primarily works on Euro cars.
Old Jan 28, 2011 | 09:24 AM
jhonmathew's Avatar
5th Gear
Please call your Rolls is a switch that has the engine speed lever to move to the selected speed and the shifter has a very soft light. Ultimately, the problem is the electric motor in the handle or gear motor, with a breakdown of them are quick or easy solutions.
Renee Nelson Barlow
Apr 1, 2014 01:10 PM
gmortie3rd
Apr 1, 2013 11:02 PM
kkrose
Apr 16, 2012 06:58 PM
Greg
Mar 28, 2011 11:09 AM
AlexDeC
Oct 24, 2006 04:32 PM
