2004 Range Rover Problems #2
Hey Folks my HSE has the inactive air suspension warning on. None of the shocks appear to be leaking since they are at the same height (4 inches or more above tire). Is this a symptom of the height adjustment or the control valves. The compressor seems to work i guess since they all are raised.
Thank you
Goldsniffer
Thank you
Goldsniffer
This happened to me last winter. It was caused by a worn out air pump. The leaking left front bladder didn't help the situation much either. I bought a EAS buddy to diagnose the problem - it said everything was just fine. From my experience you should take it in for diagnosis and save yourself some change by Not buying the EAS Buddy.
Goldsniffer
01-18-2013 09:04 PM
