2004 Range Rover Problems #2
Old Jan 19, 2013 | 09:45 AM
Goldsniffer's Avatar
Default 2004 Range Rover Problems #2
Hey Folks my HSE has the inactive air suspension warning on. None of the shocks appear to be leaking since they are at the same height (4 inches or more above tire). Is this a symptom of the height adjustment or the control valves. The compressor seems to work i guess since they all are raised.
Thank you
Goldsniffer
Old Jan 19, 2013 | 10:49 AM
LR Techniker's Avatar
Only way to know for sure is to have the Ride Control Module scanned for fault codes. Could be a sensor issue, weak compressor, etc...
Old Jan 23, 2013 | 03:43 AM
Ringo's Avatar
This happened to me last winter. It was caused by a worn out air pump. The leaking left front bladder didn't help the situation much either. I bought a EAS buddy to diagnose the problem - it said everything was just fine. From my experience you should take it in for diagnosis and save yourself some change by Not buying the EAS Buddy.
Frank4
Mar 21, 2014 05:21 AM
Goldsniffer
Jan 18, 2013 09:04 PM
rekogniz1
Oct 5, 2009 05:51 PM
cwoolner
Freelander
May 27, 2009 01:10 PM
Rustic
Jan 23, 2009 07:48 AM
