2005 RR HSE rear sway going over bumps
Old Apr 17, 2011 | 09:03 PM
Mrmerlin's Avatar
Default 2005 RR HSE rear sway going over bumps
I have a 2005 RR HSE and when doing about 70 MPH on the freeway,
when you hit a bump the rear end wants steer right or left it is very unsettling to say the least.
Has anyone had this problem, and what was done to correct it.
I jacked up each wheel and pulled at 3 to 9 and 12 to 6 no obvious movements
Truck has 63K miles. and is running in the freeway mode at 70 MPH,
otherwise the airbags all seem to be working no leakis.
Both of the rear shocks are dry,
I have not been able to test the shocks to see if one or both are blown or weak/
Thanks for your thoughts, Stan
Old Apr 17, 2011 | 10:09 PM
LRScott's Avatar
It could be a rear wheel alignment issue.
Old Apr 18, 2011 | 02:17 PM
RROJ's Avatar
check the tires. mine did that in another vehicle due the tires being worn. That is if you haven't checked them already. Only happens at high speeds right?
Old Apr 18, 2011 | 08:32 PM
Mrmerlin's Avatar
the tires are good and the rims are the 20 inch lux wheels all pressures are good .
What it feels like is a loose suspension connection as the rear of the truck wants to steer in either direction, i really need to have someone drive along and observer the wheels to see if they are flapping up and down when the truck hits a bump, i am going to install a new set of shocks .
I tried to remove one of the rear wheels and its stuck so I loosened the bolts and have to go for a slow drive to break the bonds
Old Apr 21, 2011 | 09:27 PM
Mrmerlin's Avatar
anyway I fixed this issue.
I removed the rear shocks and found the right shock would not extend to full length,
and was weak to compress compared to the new unit.
I replaced both rear shocks, and the ride is great,
nice and controlled,
new shocks at the dealer were 258.00 each,
and there is a thin gasket thats on each shock tower dont forget to swap that over
Old Apr 22, 2011 | 11:38 AM
LRScott's Avatar
Thanks for telling us how it was fixed. Not a lot of people do that and leave us here to wonder what happened .
Old Apr 23, 2011 | 09:45 PM
Mrmerlin's Avatar
I am glad the shocks fixed the issue, it was pretty scary the first time it happened, as i just bought the truck and was driving it 950 miles back to home base.
deer4011
Jan 12, 2021 07:10 AM
Pwoens
Oct 5, 2012 01:30 PM
SolbergFanBoi
Mar 5, 2012 07:05 PM
wanjman
Dec 28, 2011 09:08 PM
Speed racer
Nov 11, 2009 09:44 AM
