Clunks over bumps
Old Oct 2, 2012 | 11:58 PM
Pwoens's Avatar
Default Clunks over bumps
When I go over speed bumps I feel a good clunk in the floor. I have the upgraded front driveshaft and the rear has no play. The disco is new to me and not sure if there's a common place to check? Also a decent vibration around 60-70??
Old Oct 3, 2012 | 05:47 AM
coors's Avatar
Look at the Motor mounts (2) and Trans Mounts (2). Then inspect the rear bushings for play.
Old Oct 3, 2012 | 10:19 AM
Is you 1" lift, spacers if so you are still running on a very warn set of factory shocks.
What have you checked so far??
Old Oct 3, 2012 | 05:39 PM
toad2's Avatar
My old Disco clunked at the back and it turned out to be the Watts linkage bushings . Wasn't complicated to fix, just a PITA.
Old Oct 5, 2012 | 12:13 PM
nychaze's Avatar
My disco would clunk when the suspension was compressed going over speed bumps...turned out to be a bad shock.
Old Oct 5, 2012 | 01:30 PM
ruffram's Avatar
Do you feel this clunk in the floor when going around tight turns or only on sharp bumps? Mine was making a slight vibration at highway speeds recently and it was the rotoflex that had a slight tear in it. Replaced that and vibration was gone
SolbergFanBoi
Mar 5, 2012 07:05 PM
Mrmerlin
Apr 23, 2011 09:45 PM
Prowler9876
Feb 8, 2010 05:53 PM
mirko_gardilcic
22
Nov 3, 2009 10:49 AM
ajh
Aug 22, 2007 05:30 PM
