2006 HSE Rear Passenger Window Cable Off Track
Old Aug 1, 2012 | 11:27 AM
Jay Adam Harper's Avatar
3rd Gear
Default 2006 HSE Rear Passenger Window Cable Off Track
Hi Everyone, hoping you can get me a little help.
My rear drivers window went CLUNK one day. From there the switch is a "no touch" situation.
While driving, the window slowly lets itself down.
I removed the door panel to find a massive black glued down noise barrier. I peeled that back some to get a peek inside and there is a wire, looks like a looped cable that is simply hanging in the door frame.
I could see nothing else and I could swear I heard something fall to the inside of the door frame when it happened. I reached my hand down in the bottom of the door and found nothing, so I assume it was just the cable.
Anyone have any ideas on how to fix this without a trip to the dealer?
Old Aug 1, 2012 | 08:16 PM
Rovin4life's Avatar
You need a new regulator and a reprogram of the window ecu to prevent the problem again. 03 to 06 RR had the issue.
Old Aug 1, 2012 | 09:10 PM
LR Techniker's Avatar
Ditto what was said above with one addition: Make sure you re-adhere the barrier to the door frame. Water leaks pop up when it doesn't get sealed correctly to the door.
Old Aug 2, 2012 | 09:08 AM
3rd Gear
Ok thanks for the advice. I guess I should just let the dealer handle this.
Old Aug 2, 2012 | 11:28 PM
Mrmerlin's Avatar
If your crafty enough to remove the door panel then you can easily swap out the window regulator its not that difficult.
Old Aug 3, 2012 | 10:33 AM
3rd Gear
I like the way you talk. I suppose I need to full remove the black seal thing and take a better look inside. I have been unable to find any photos of what's going on in there and it also seems like I saw a link somewhere to a site that sells those regulators on the cheap. hmmm
texmanmoore
Jan 26, 2009 09:36 AM
slave600
Oct 11, 2008 08:51 PM
trellis8
Mar 9, 2008 08:27 AM
ggushee
Feb 6, 2007 09:03 AM
