89 rangerover classic turning signals not working??
Old Jun 6, 2012 | 07:17 AM
4x4lover's Avatar
Exclamation 89 rangerover classic turning signals not working??
hello, after i got my range rover to finally run, i came across the issue of my turn signals not working or the break lights , like when i turn on a signal it doesn't work but my hazard lights work perfectly fine and the actual turning signal bar seems to be working fine i can turn on the brights but it won't activate either sidefor the turn signals (also the front turn signals don't do not activate)
anyone know anything about this problem??
thanks,
cameron
Old Jun 6, 2012 | 10:00 AM
Could still be that switch, it has more than one section of contacts. Here's schematic if you don't have the RAVE (hope you do, if not it is also below).
File Type: pdf
Old Mar 16, 2013 | 08:38 PM
Psycronic's Avatar
4x4lover, did you fix this issue? I've got the same problem with mine.
hazards work, but indicators and brake lights don't
Benjamin Wright
Feb 23, 2013 10:22 PM
Landlover12
Apr 2, 2011 12:27 PM
kumbhani123
Nov 18, 2009 07:23 AM
rka12321
Apr 19, 2008 01:44 PM
DivebombInc
Jan 14, 2008 01:09 PM
