91 classic ABS PUMP/relay issue
Old Apr 10, 2008 | 10:24 AM
tre976's Avatar
Default 91 classic ABS PUMP/relay issue
So my pump is running after the rover is turned off and sounds horrible ( happened just once so far ) - after googling I found that Ishould replace the ABS relay(s) first. Is there just 1 relay or 2? And are they/it under the driver seat? I found an older post of someone who swapped out a 30a circuit under the seat but I'm unsure if thats the same thing.
Dap-INC has the ABS relay listed at 36 bucks or so, is there another alt to use -much like the stepper motor alt ?
thanks!
Old Apr 15, 2008 | 10:35 PM
tre976's Avatar
Default RE: 91 classic ABS PUMP/relay issue
could someone confirm that the relays are under the driver seat in the ecu??
Old Apr 16, 2008 | 08:33 PM
northcountry32's Avatar
Yes the relays are under the seat with the ecu. There is a pump relay and a load relay.
bleizit
Jun 24, 2020 04:03 AM
Travelor
Sep 24, 2015 06:11 PM
RicketyTick
Jun 24, 2014 06:58 PM
s10lowrider1994
Oct 6, 2011 01:22 AM
skatelove303
Aug 16, 2010 02:03 PM
