93 Range rover LWB front axle failure - can I drive it 2000 miles like this?
Old May 10, 2012 | 01:07 AM
DeLorean's Avatar
Default 93 Range rover LWB front axle failure - can I drive it 2000 miles like this?
First post here, and in a bit of a bind... possibly.
So diagnosis on this at this point has been minimal, but I am about to do further checks to be sure we have an axle failure. We are currently on a road trip with the car, out in Oregon... We live in PA. First symptoms were a light vibration, and "clunky" feeling shifting. Also noticed that the car lost 4WD function (it will now only spin only 1 rear wheel in mud and does not seem to power the front wheels). Today, when the car was in park it rolled down a slight incline slowly while we were away from it.
To drive, it feels a bit like it's attached to a long chain (i.e. feels like it has a ton of drive line lash.
Tomorrow, we plan on jacking it up on each corner and checking to see if each wheel spins individually to verify we if we have lost an axle.
We have tools on hand, and should be able to swap an axle if we need to. If it's not an axle, and turns out to be a front differential, transfer case or similar, how bad would it be to drive it 2000 miles with the front drive shaft out of the car, would that even help? As it sits, it drives- but feels pretty funky. We have about 2000 miles to get it home...
Old May 10, 2012 | 05:04 AM
If you don't have your RAVE, on-line access in my signature.
You can drive with front propshaft off if CDL engaged.
You would want to drain diff and look for metal.. If you find any, perhaps flush with lots of thin mineral spirits, etc, to get any chunks out that you can, while turning slowly and safely supported. Refill with 85W150 gear lube, and maybe even a tube of regular bearing grease (makes a pudding).
Old May 10, 2012 | 12:14 PM
DeLorean's Avatar
It's a 93 range rover, they don't have a center diff lock. I have 4H and 4L with a viscus coupling and 2 open diffs front & rear.
Old May 10, 2012 | 12:18 PM
Sorry - my mistake.
Old May 10, 2012 | 01:15 PM
Found this in the RAVE about the viscous clutch - it seems that it removes the need for a CDL, so with front shaft off it should make rear work, may be a slight delay as jelly has to change viscosity.
During normal driving conditions, slight variations in
the relative speed of each drive shaft is insufficient to
increase the viscosity of the silicon jelly. Therefore the
resistance within the viscous coupling is low.
In off-road conditions, when the wheels lose grip on
loose or muddy surfaces, a greater difference in the
rotational speeds of the front and rear drive shafts
exists. The slippage, due to the difference in rotational
speeds of the drive shafts, within the viscous coupling
agitates the silicon jelly causing heat which increases
the viscosity. The increased viscosity increases the
drag between the discs forcing both sets of discs to
rotate at similar speeds, reducing axle slippage and
increasing traction. The viscous coupling removes the
need for a manually controlled differential lock.
Old May 12, 2012 | 09:33 AM
jafir's Avatar
I'd be afraid it would burn up the viscous coupler if you drove around like that for too long... if it even will drive like that. There might need to be at least some friction on the opposite side for it to work... not sure.
Maybe the viscous unit is what's broken anyway? But the ashcroft site says when they fail the usually fail in a locked up state. But then that could cause the CV or diff to fail.
Ashcroft Transmissions - Range Rover Viscous Coupling
Old May 13, 2012 | 09:01 PM
hilltoppersx's Avatar
My bet is the front pass side half shaft.
tnf
Jul 26, 2012 03:36 PM
TripleThreat
Apr 12, 2011 08:58 AM
ebrover
Dec 23, 2007 10:16 PM
Randy P
Sep 27, 2007 08:27 AM
das
May 26, 2007 10:42 PM
