P38 new member needs help plz
Old May 14, 2012 | 02:54 PM
seany100sean's Avatar
Default P38 new member needs help plz
Hi, my P38 speedometer is not working.
have purchase replacement BECM because of other issues which are sorted. but when i purchased the vehicle the previous owner did'nt mention the speedometer not working, and i trailered the vehicle home,
So now i need some expert advise please
Thanks
Sean
Old May 14, 2012 | 04:25 PM
See attached schematic. Appears to be a drive from the ABS controller (averages all four wheels).
From RAVE:
Speedometer
The signal to activate the gauge is originated at the
ABS wheel sensors, transmitted to the ABS ECU
(Z108) which then puts out a usable signal to the
Instrument Cluster (Z142) of 8000 pulses per mile or
4972 pulses per kilometer. The signal is also
transmitted to other ECU’s, such as the Engine
Control Module (ECM) (Z132) and the Cruise Control
ECU (Z121).
A scanner or Ultra gauge should pick this up from the OBDII port (vehicle speed) if sensors and ABS ECU and engine computer are working. Could be a mere wiring problem.
File Type: pdf
nicklaeena
Jan 30, 2013 11:58 AM
louiev
May 30, 2010 09:40 PM
L R Novice
Sep 8, 2009 09:28 AM
natem2112
Oct 17, 2008 04:47 PM
instantfly
Off Topic
Jul 27, 2007 06:50 AM
