94 RRC LWB Battery died....replaced. No start...Please help
Old Dec 13, 2012 | 07:41 PM
James Sutton's Avatar
5th Gear
Default 94 RRC LWB Battery died....replaced. No start...Please help
I literally had battery die overnight. I went to buy a new one and swapped it. Dome lights work. central lock works.
go to turn key and it turns all the way to start but ignition doesn't light up dash , its like there is a ignition immobilizer? I feel like an idiot but I am stranded at the parents house while traveling cross country and I would rather be stuck in the desert than here.
any help would be appreciated! thanks in advance.
Old Dec 13, 2012 | 08:22 PM
It is always a good idea when replacing a dead battery to hold down the hood alarm switch, so when truck wakes up it doesn't think it is being stolen.
Old Dec 13, 2012 | 08:28 PM
take a peek at this Battery Replacment and Upgrade you may just have to put the key in the ignition and let it sit for a few minutes to resync.
Old Dec 13, 2012 | 08:33 PM
5th Gear
thanks I will try that.
And I do not have any aftermarket electronics. this is a bone stock rover.
Old Dec 13, 2012 | 08:39 PM
I'm lucky to afford old and oem, even if some of it comes from the boneyard.
Old Dec 13, 2012 | 10:39 PM
5th Gear
I tried all sequences and resets. Im at a loss now......
power windows do not work , i can hear the relay click when i push the shifter button in.... but it wont let me slide it out of gear to try neutral safety switch... neutral start.
Can i rip out the stock alarm system and that will free my ignition?
Old Dec 13, 2012 | 11:17 PM
see https://landroverforums.com/forum/di...ization+bypass for more ideas
Old Dec 14, 2012 | 03:39 PM
5th Gear
well I am going to take apart the ingnition housing and check that. recheck the ground and hopefully it will fire up. I am just scratching my head lol
Old Dec 14, 2012 | 05:04 PM
5th Gear
Key / tumber ans ignition assembly all function with continuity test. I have been stranded for 2 days. I am pulling my hair out.... someone send me a 6pack
Lgolf81
LR2
53
Sep 7, 2023 01:56 PM
WNYErikDiscoII
Nov 7, 2013 09:32 AM
malibuman09
Nov 18, 2012 01:59 PM
Honey Sterling
Oct 8, 2012 09:42 PM
Lincoln Tarantino
May 2, 2012 11:20 AM
