95' p38 fuse..
Old Feb 28, 2011 | 05:59 PM
devonseang43's Avatar
Default 95' p38 fuse..
My driverside and passenger window wont roll down but both back window does..im guessing its the fuse BUT I dont wanna mess with the fuses because last time my bro was checking the fuses, and pulled out the anti theft fuse and the whole entire car just lock. It wouldnt even start. I guess the anti theft came on( bad experience). i had to tow my car to the land rover dealership so they could reset the car. Any suggestion on where the front windows fuses is located or where i can purchase a 95' range rover user manual book?
Old Feb 28, 2011 | 11:00 PM
handsome rob's Avatar
If your rear windows are working then it should not be a fuse. I would pull up the switch panel that has the window switches and swap them around and see of the switches for the back ones will work the fronts. This will rule out the switch and let you know if there is an issue with the regulators. Plus when you are looking at the connector you can use a multimeter to see if you are getting juice to the switch and then rule out any power issue.
Old Mar 1, 2011 | 02:56 AM
oh okay. Im going to check that out. =D
1995 Range Rover white
iambhooper
Feb 20, 2014 07:17 PM
Blakesrover
Feb 21, 2013 01:43 AM
devonseang43
Feb 27, 2011 05:01 PM
nickm347
Jan 10, 2011 09:28 AM
hecareth
Feb 20, 2005 11:31 PM
