95 Range Rover SE, A/C, Bypass system?
Old Aug 15, 2012 | 03:11 PM
FoxxTrixx's Avatar
Default 95 Range Rover SE, A/C, Bypass system?
My RRSE will not activate the A/C via normal controls. The compressor works if powered independently. If I rewire and install a switch, will that blow out the compressor? I truly don't know what to do except pay some mechanic through the f'ng nose to fix it. It isn't fuses, relays, or anything obvious (all checked). If I wire it direct and control with a switch, it will work, but I'm concerned it will cause problems because it is too easy of a solution. Bear in mind I am not a mechanic but someone who learned to Rube Goldberg stuff to make it work.
Old Aug 15, 2012 | 04:54 PM
RoverMasterTech's Avatar
it's either empty, (bad condenser) or the trinary switch is shot. Either way AC is for the pros.
Old Aug 15, 2012 | 08:03 PM
Dr. Goldberg, if you apply direct power to the compressor eliminating all safety circuits, the compressor can self destruct just like running the engine without oil. There is a reason they have safety limit switches, and it protects the high dollar compressor and your wallet. If there is no refrigerant present, it had to go somewhere, so the pro will find the leak, repair, vac system down to get rid of any water, and refill with proper quantity of refrigerant. By the time you buy a set of gauges and a vacuum pump you have spent most if not all of what a basic service costs. And you have not even come close to the cost of the refrigerant recovery machine. Running an AC compressor without refrigerant and oil is like running motor without oil.
Old Aug 15, 2012 | 09:24 PM
Originally Posted by savannah buzz
dr. Goldberg, if you apply diect power to the compressor eliminating all safety circuits, the compressor can self destruct just like running the engine without oil. There is a reason they have safety limit switches, and it protects the high dollar compressor and your wallet. If there is no refrigerant present, it had to go somewhere, so the pro will find the leak, repair, vac system down to get rid of any water, and refill with proper quantity of refrigerant. By the time you buy a set of gauges and a vacuum pump you have spent most if not all of what a basic service costs. And you have not even come close to the cost of the refrigerant recovery machine. Running an ac compressor without refrigerant and oil is like running motor without oil.
...........................................shazzzz zzam!!!........................................... .............
yukonridin23
Oct 29, 2009 10:21 AM
baysentp
Sep 5, 2007 08:32 AM
suveer
Jun 13, 2007 12:36 AM
suveer
Apr 26, 2007 05:26 AM
MercadoRR
Sights N Sounds
Mar 17, 2006 05:00 PM
