96 4.0 hse
Old May 18, 2005 | 03:55 PM
p.tandy's Avatar
Default 96 4.0 hse
my 96 4.0 hse rangerover overheats when working hard or travelling at over 90 mph for a while,if you slow down below this speed or ease off the throttle the temp soon returns to normal,i have changed the rad,waterpump,viscous fan &t/stat,it does not pressurize the water system, last weekend i replace the head gaskets & skimmed the heads as it was the only thing left that i could think of but still the same. The only thing i now can try is fitting genuine parts rather than non gen. but dont have much hope that this is the problem,if anyone has had similar problems please let me know.
Old May 19, 2005 | 12:52 AM
Bait's Avatar
Default RE: 96 4.0 hse
Is it actually boiling off coolant, or just temp gage reading high ?
Old May 19, 2005 | 08:49 AM
p.tandy's Avatar
i am sure it is getting hot because if i dont slow down it continues to get hotter until in the red,the gauge normally stays right in the centre no matter what type of load it is under.
Old May 20, 2005 | 02:39 AM
Bait's Avatar
If you are not loosing coolant, there is a TIB on this issue. It has to do with the temp sender ground.
CPTLOU
Feb 3, 2014 06:06 PM
ICECREAMEATER
LR4
Jun 7, 2012 06:53 AM
akondor
Mar 12, 2010 05:37 PM
danohameed
Mar 8, 2010 03:54 PM
Stickestar
Appearance & Camping Set Ups
Dec 13, 2006 03:25 AM
