98 RR NEED HELP???only94k
Old May 3, 2007 | 06:15 AM
wease206's Avatar
Default 98 RR NEED HELP???only94k
Since the last time we have chat i found out it was the head gaskit andRocker shafts all fix no more lifter sound vey happy
Now my RR has this problem
(Rear diff pinion seal >T-case output shaft seal >Heater core o-rings) is iteasy to fix, can i do this myself and going under the car andin thehood in front of my house this there a way i could get some information how to do this i want to learn. were can i get these part from i have contected roverconnection they have got back with yet. are these a common problem?[:'(]
Old May 5, 2007 | 02:10 PM
nanin's Avatar
Default RE: 98 RR NEED HELP???only94k
Hi there, I have a 1998 Range Rover Too. And I just bougth it a few time a go. I´m not shure if those things that you said are common problems. I just start to be familiar with mine. I used to have a Land Rover Series I and Series III so this Range Rover are like a if I have been travel in time to the future and I´m not felingsecureto work on the Range Rovers by myself. However, here are some links that you can see some options to get parts. May someone have more links.
http://www.roverparts.com
http://www.roversnorth.com/
Old May 5, 2007 | 06:06 PM
Depending on the type of part you are looking for go to RoverConnection.com or DAP. Both of thes site have many more parts at better prices.
So how bad is your pinion seal leak and your t/case leak? Are they leaking to the point of dripping or are they just seeping?
Mike
Old May 5, 2007 | 11:57 PM
wease206's Avatar
no! it can last maybe 3-mth.I have found the part is it easy to install these parts? Please help me?
love the rover man
ScreamingLife
Apr 25, 2013 08:32 PM
MuddMouth
Oct 18, 2010 03:01 PM
striversrowatl
May 1, 2010 11:20 AM
Speed racer
Oct 11, 2008 10:56 PM
