ABS Traction control problem after using EAS Unlock Software
Old Oct 7, 2009 | 10:46 PM
krazzz's Avatar
Default ABS Traction control problem after using EAS Unlock Software
Just when I thought I had all the bugs worked and it was working 100%.
Well tonight I located the last air leak in my EAS (air line at the valve block.) I sat in my truck, fired it up and then turned on the EASUNLOCK software so that I could depressure the air bags and tank. Shortly after pugging it in the truck beeped and the ABS/TRACTION CONTROL lights/messages came on. I hadn't touched anything near the wheels and I hadn't even gotten out of the truck. How could the EAS software mess up the ABS/traction?? Are the two systems linked in some strange way? What in the world is going on here? I have never had a problem with them before and it was working when I parked it. What gives? I guess the Rover gods didn't want me to get too comfortable with all my free time.
Old Aug 17, 2012 | 12:00 PM
lwilliams1922's Avatar
4wd High
Did you ever find an answer to this?
I'm having EAS problems and also the traction control light came on.
(I also have a 98 Volvo)
Old Aug 17, 2012 | 05:17 PM
LR Techniker's Avatar
Do you have any way to scan for fault codes? Normally when I'm scanning a vehicle, its not usual for the ABS lights to come on, as the scanner communicating on the data bus sometimes interrupts data transmission to the ABS unit, but once I'm done scanning the lights go back off.
Old Aug 17, 2012 | 05:19 PM
4wd High
I have the EAS un lock software. It give errors but it does not seem to be consistent.
Sometimes there are 12 errors, sometimes there are none.
umwolverine
Sep 14, 2012 09:45 PM
gamecockdisco
Jul 12, 2010 08:34 AM
richierichrover
May 27, 2009 09:42 PM
rodrick smith
Apr 13, 2007 06:09 PM
