Airbag Fault
Old Sep 15, 2006 | 02:08 PM
faheemf1's Avatar
Default Airbag Fault
Whenever I start my car in the display it shows a message saying Airbag Fault. The dealership told me that its a sensor at the passenger side airbag. Is there any way I can replace it myself? Help please....
Old Sep 16, 2006 | 07:22 AM
put_the_winch_away's Avatar
Default RE: Airbag Fault
what model is it im guessing somthing after 1993 , i know with the classics and the p38a's, the height sensor it is easy to replace. three bolts, little armature thing, and a plug.. hope helps
Old Sep 16, 2006 | 01:00 PM
Need clarity, which air bag system, the SRS or your suspension?
Mike
Old Sep 25, 2006 | 09:51 PM
lmmnny's Avatar
4th Gear
I have 97 RR with the same problem,it shows Air Bag fault and the SRS light is on.The dealer said it does not register in there computer and they have to check everything which means big bucks.Pls. help if you have any suggestions.Thanks
Old Nov 18, 2006 | 03:12 PM
DaRovers's Avatar
Well i pulled all of the fuses out of my truck 2000 range rover 4.9 hse. cause the brake lights were stuck on. Turned out the switch at the pedal was a lil stuck BUT now i get SRS light, Airbag Fault, ABS Fault, Traction failure on the computer with beeps. DAMN
Old Nov 18, 2006 | 04:38 PM
ORIGINAL: DaRovers
You can't just go pull fuses, or you land up with what you now have, a bunch of warning lights thet the dealer is going to have to clear or reset.
Mike
Old Nov 19, 2006 | 07:28 PM
DaRovers's Avatar
I got the codes out of the computer for the following service engine soon, SRS, Airbag fault, ABS fault, Traction Failure. lights and beeps.
on a SPX OTC autocode model OTC3407 (not sure if that is an accurate machine for this car)
PO174 too lean
P0733 which is that gear ratio thing for gear three.
and the rest were miss firing cylinders.
which leads to this discovery (no pun) when the pedal is floored the engine will rev to 3k rpm then cut back
and when driving accelaration is fine until the pedal is completely pressed to the floor. Once pressed to the floor the car cuts back again, i am bringin it over tomorrow to my mechanic[:@].
The srs light did go off for a min then popped back on....
Old Nov 19, 2006 | 10:23 PM
esaycho's Avatar
those are only the codes for the check engine light, you need one of the fancy dealership computer to get the Airbag, Brake and other systems codes
Old Nov 20, 2006 | 01:21 PM
DaRovers's Avatar
AHHH DAMN IT... thanks.
Old Dec 7, 2006 | 01:13 PM
DaRovers's Avatar
ANYONe PLEASE... LOL i need to find out the best book for a range rover 2000 4.6 HSE and the best computer device to get the codes.. i am going to have to buy this stuff.. I am going to chek the site Mike recommends.
