Any ideas?
Old Dec 5, 2011 | 12:22 AM
Crosbo's Avatar
Default Any ideas?
My friend has an '01 SE and it was running well and operating perfectly. Then he had the rig detailed and now washer pump won't stop running and the right high beam light stays on. Also, the right turn signal light and side light stay lit, albeit intermittently. Only the right side.
He disconnected the washer pump and has now disconnected the battery. Otherwise the battery winds up being drained.
Any idea what is causing this?
Old Dec 5, 2011 | 02:05 AM
LRScott's Avatar
Pressure washers can cause problems if the fuse/relay box was sprayed too heavy. Mine started smoking when I did mine... I un-plugged the battery and let it dry out. Everything was normal afterwards. If your friend can park the rover in a warm garage and let it dry for about 8 hours or so, that might fix the issues. If it does not, the electrical system might have been damaged.
Old Dec 5, 2011 | 04:37 AM
Underhood fuse box may have water inside, the relays may be sitting in water. If so also remove relays and dry the base and pins.
Old Dec 5, 2011 | 09:20 PM
Crosbo's Avatar
Thanx for the suggestions gents. I'll pass the info along.
tigertrakstar1
Mar 5, 2014 04:13 PM
Jameslandrover110
Defender
Feb 18, 2011 02:46 PM
Damiean
Aug 22, 2007 01:34 PM
RTWoerner
Jun 13, 2007 11:22 PM
bksy1
Freelander
May 23, 2005 01:18 PM
