Bearmach Hawkeye Land Rover Diagnostic
Old Feb 12, 2014 | 03:49 PM
Denny Smith's Avatar
4th Gear
Default Bearmach Hawkeye Land Rover Diagnostic
Question, with a Bearmach Hawkeye Land Rover Diagnostic tool reset the abs lights and read their codes?
I recently had an issue with whats called the "3 amigos" where three lights come on together. The lights would come on when depressing the peddle and then they would go out leaving only the ABS light.
I read a tutorial about the ABS accumulator pump as a "quick fix" for this type of issue. The only thing is, now they all three stay on all the time now.
Thanks
Old Feb 15, 2014 | 10:29 PM
tuercas viejas's Avatar
Yes that tool will work. I used it in Costa Rica , but more on diesel engines (Independent shop in San Jose CR)
On a P38 don't overlook the brake switch or "slack" in the pedal pivot.
Both will activate the "los tres amigos" if out of adjustment or the pedale isnt returning in a positive fashion to compress the brake switch plunger.
Note the brake pump should operate for about 15 to 30 seconds from cold to raise brake residual pressure. Be wary of constant running after 45 seconds this indicates a worn pump, accumulator defective or valve block (brick).
Andele pues
TV
Chris-bob
Dec 18, 2020 01:12 PM
jycsalas
Oct 28, 2013 02:23 PM
TRIARII
Jan 26, 2013 04:54 PM
jycsalas
Dec 11, 2012 08:54 PM
tsam19
17
May 31, 2012 03:02 AM
