BeCM Problem? Range Rover 97 4.0
Old Nov 28, 2005 | 04:07 PM
Richard1's Avatar
Default BeCM Problem? Range Rover 97 4.0
Dear All,
My 97 4.0 Range Rover is experiencing weird electrical problems....lights flashing, horn wont go off, error messages on fuses. The weirdest of all is that even with the ingnition turned off, the engine continues to idle, though the dash doesnt show readings.
First thought is the BeCM has gone south. But, could it be a ground problem? I installed a EAS bypass as part of a coil conversion about a month ago and it was working fine but other thought is a problem with the bypass module. Thank you for your assistance.
Old Nov 30, 2005 | 04:40 PM
Richard1's Avatar
Default RE: BeCM Problem? Range Rover 97 4.0
I will tell you that it is in fact the BeCM. The cost of the part is $1000 to $1300 depending upon where you buy it. Buying a used one will do you know good unless you can find a way of clearing the BeCM so that it can be reprogramed...something the average land rover wrench simply cannot do. Good luck to all of you who face a similar issue.
anniepetunia
Aug 3, 2011 11:47 AM
anniepetunia
Aug 3, 2011 08:11 AM
climberbruno
Jun 15, 2008 08:52 PM
2000rrhse
May 30, 2007 04:37 AM
havhon
Feb 21, 2007 11:44 PM
