best way to paint rims?
The best finish would actually be to powder coat them. Most factory rims that look painted are powder coated. This is not cheap and you could plan on spending about $400 to do this. Paint is cheaper but it is much less durable. If you are set on painting them the best thing you can do is have the tires removed, media blast them and then primer and paint. To get them painted for $100 would be a steal if he does quality work.
I've painted 4 or 5 sets of wheels over the years. Easier with the tires off but it can be done with them on if you are a patient guy with masking tape. Sand the existinig paint/powder with 200 then 600 grit before the first paint coat, then clean with mineral spirits or a designated paint prep cleaner then wash with water.
As mentioned before, prep and cleaning is of utmost importance to avoid fisheye and orange peel in the paint. I like to go with 3 to 4 coats max, with a 1500 grit wetsand in between each coat, then 2 coats of clear, wetsand after the first but not after the final coat.
After the paint cures a nice coat of quality boat wax like Collonite helps protect them for a long time. With patience and attention to detail you can get a great looking finish that is strong and durable.
Cut-In Clear
I did my restored Jeep chrome rims using sherwin williams cut-in clear (the originals were clear-coated but it got milky after 25 years). I did mine with the tires on, you just need to take the wheels off, strip, tape, and spray. I would use a good 2-part automotive paint if you have a sprayer, otherwise your black paint will chip off. The cut-in clear is VERY thin, so if you did something like this, I would use many, many coats. It might not work over regular paint, it's designed to go over 2 part (hardened) paints.
Beamer1
04-20-2012 01:39 PM
