brake issues with my 97 rover !!
Old Jun 17, 2008 | 12:53 AM
lonely king's Avatar
Default brake issues with my 97 rover !!
hey guys,,iam having brake issues with my 97 rover..i changed the pads and rotor and my driver side brakes and rotor started to smoke..so i changed the caliper thinking maybe i damaged it when i compressed the pistons back in..so so i changed it out , i did bleed the system out and drove it ,the driver side brakes/rotor is still smoking????the other side is fine...this is driving me nuts !!!ANY IDEAS WHAT MAYBE CAUSING THIS ??i changed the rotor and caliper ???
Old Jun 18, 2008 | 12:12 AM
Default RE: brake issues with my 97 rover !!
any help guys?
Old Jun 18, 2008 | 07:07 AM
alsuch's Avatar
My only thoughts are that maybe you've got a proportioning valve issue. It's probably time for you to consult a local professional on this problem.
Old Jun 18, 2008 | 07:22 PM
your probably right..i was told maybe the brake line going from the calpier to the p valve is dirty and stuck .,might have to get awhole new line. does that sound right ???
Old Jun 21, 2008 | 07:29 AM
alsuch's Avatar
Sounds feasible anyway.
Old Jun 21, 2008 | 11:38 AM
roverguy7's Avatar
check your caliper slides, if theyre not moving right, itll cause the caliper to hang up, you should be able to move them in and out easily... the things the caliper bolts go into
Old Jun 21, 2008 | 12:18 PM
the calipers are not locking up ..i checkedthem out..i took it to a mechanic and the smoke has gone away slowly..he thinks i was burning up the grease in between the vents,the one it come to protect it from rusting.i cleaned the sides, but not in between the vents on it..seems to be fine now..brakes are grabbing fine as well.
mwill06
Dec 13, 2010 06:20 AM
ArtemZ
Jun 29, 2008 03:04 PM
bavarian_range89
Dec 29, 2007 02:56 AM
97XD
Jun 1, 2007 12:17 PM
richo888
May 12, 2005 11:50 PM
