Broken Hub/Axle on my 94 RRC
Old Jun 14, 2009 | 02:35 PM
DucsNDirt's Avatar
3rd Gear
Default Broken Hub/Axle on my 94 RRC
I came across a "slight" problem when going over my new project range. Funny story too. I just picked my new Ypipe for it and just got home. I wasn't feeling too hot that day so i just put in the garage and was gonna call it a day.
But i also picked up some back to black and wanted to see how it would restore some of the faded vinyl and plastics. So I tried some on the left rear taillight trim piece for the guards. (missing the guards though...) When all of the sudden i start to hear. PPPPPPPSSSSSSSSSSSTTTTTTTTTT
The left rear tire started pissing out from the valve stem. I guess that little bit of motion just made the stem break the seal.
So I got it on a stand and took the tire off. Then i noticed something was up.
All 5 axleshaft/hub bolts were sheared and broken beyond belief. The axle shaft came sliding out.
Part of the axle scored up pretty good too.
So from what i can tell I need a new hub/wheel stud plate, 5 bolts, and a new axle shaft.
I also know that i need new seals, washers, bearing etc...which I coincidentally found in the parts boxes the guy gave me. Leading me to believe he knew about it and didnt say boo.
So i was looking at these parts here and im pretty sure are them, but i would love if someone had a few pointers on this repair and if the parts im looking at are correct.
Here's the hub piece im looking at: http://www.roverparts.com/Parts/FTC942.cfm
The bolts: http://www.roverparts.com/Parts/BX110095M.cfm
The axle shaft: http://www.roverlandparts.com/1994-1...sicandlwb.aspx
Everything i think i have. Any help is appreciated. Thanks
Old Jun 15, 2009 | 09:20 AM
LRScott's Avatar
There is a nice little tutorial on this for the P38a but not the classic unfortunatley. Here is the one for the P38a but I doubt I would do you any good http://www.rangerovers.net/repairdet...rain/hubs.html. You might want to consider downloading the rave manual for range rover classics. Here it is if you do not have it yet: http://green-oval.com/joomla/index.p...d=13&Itemid=29
It should be the first one on the list "Discovery I and Range Rover Classic" It will show you how the axle is constructed and might even give you steps on how to replace it. Good luck on your project.
cationmoted
Oct 19, 2012 07:39 AM
kman3786
Jun 6, 2010 01:01 PM
Disrover
Aug 21, 2009 09:47 PM
98xc800
Sep 30, 2008 04:51 PM
DISCOHAITI
Aug 27, 2007 09:09 AM
