Check Brake Pads, replaced sensor - still have error
Old Feb 23, 2014 | 11:15 AM
tims911's Avatar
6th Gear
Default Check Brake Pads, replaced sensor - still have error
I have the normal 'Check Brake Pads' alter on my 08 RRS. Brakes are fine and the sensor was not tripped. I replaced it anyway, but still have the error. I only see a front, left sensor and not a rear sensor. Ideas?
Old Feb 23, 2014 | 02:00 PM
LR Techniker's Avatar
Pad sensors are located on L/F and R/R corner. No sensor installed on R/R = reason for BRAKE light.
Put a sensor in the rear.
Old Feb 23, 2014 | 05:37 PM
Fivespddisco's Avatar
The tiny pins on the sensors get bent and do not make contact when you plug them in. I would unplug and check them
Old Feb 24, 2014 | 07:16 AM
tims911's Avatar
6th Gear
There is a sensor on the right rear of an 08 RRS HSE? The parking brake axle? I took that wheel off and didn't see a sensor. Thanks, I would have missed it.
Old Feb 25, 2014 | 07:28 PM
Yes, it has a sensor (or should). Its part number: SOE 000025
The connector is behind the inner fender liner.
Bryan H
Oct 11, 2010 06:07 PM
kallgrer
Jul 24, 2010 08:56 AM
Florida04RR
Mar 10, 2010 06:09 AM
gmal
Jul 9, 2009 11:27 AM
Gavster
Jun 17, 2009 08:50 AM
