Check Brake Pads error code
Old Feb 14, 2009 | 04:15 PM
gmal's Avatar
6th Gear
Default Check Brake Pads error code
Looking for some help on this error code.
I replaced the rear rotors, pads, and pad wear sensor on my '03 Range Rover.
The old sensor broke on removal and gave me the error code "Check Brake Pads". I replaced the wear sensor but am still getting the error message.
Any tips/advice? How can I reset/clear the error message?
thanks in advance.
Old Feb 14, 2009 | 09:28 PM
roverguy7's Avatar
turn the key on, engine not running, for 45 seconds with all the doors closed. the light will turn off
Old Feb 15, 2009 | 08:37 AM
gmal's Avatar
6th Gear
Perfect - thanks - that did it.
Took less than 45 seconds.
Key was turned to the "on" position (the position just before starting the engine), all the warning lights came on, and about 15-20 seconds later the warning light cleared.
Old Feb 15, 2009 | 10:45 AM
roverguy7's Avatar
huh, guess i count fast
Old Mar 15, 2009 | 07:27 PM
de6624's Avatar
Default I get the same message
I changed my pads bout 6 months ago,,hardly use the truck, i have a 2003 RR hse, and i got the check brake pads code. How long should you usually wait to get this fixed, I was going to hold off till friday, is that safe?
Old Mar 16, 2009 | 04:35 PM
roverguy7's Avatar
designed to trip at 2 mm, so if your rotors are good, then yeah, shouldnt be a problem to let it go a week. however, check them, just get a light and take a look, you might have to move the car back and forth til you get the right angle to see in through the wheel, but if you can see pad, and no shinny metal dust all over the place, youll be fine for a week
Old Jul 9, 2009 | 11:27 AM
japhillips's Avatar
3rd Gear
Dave does the "turn the key on, engine not running, for 45 seconds with all the doors closed. the light will turn off " trick work for the 2006 LR3???? I can't get my light to go off.
tims911
Feb 25, 2014 07:28 PM
FlyingZebra34
Feb 22, 2014 05:39 PM
pixel
May 13, 2011 07:24 PM
Florida04RR
Mar 10, 2010 06:09 AM
ljdiscovery
Jan 17, 2009 01:35 PM
